Export storyboards
Version2025r3
LanguageEnglish
You can create a storyboard by pasting together video sequences into one cohesive flow and then export it.
  1. In playback mode, start by opening a view that contains items that you want to add to your storyboard.
  2. In the timeline, click SC_TimelineControl_TimeSelectionMode_icon.png.
  3. Select the start time and the end time for the storyboard.
  4. For each item in the view that you want to add, select the corresponding check box Export_video_in_advanced_mode.jpg and click Export > Add to export list.
    Repeat steps 1-4 until you have added all items that you need for your storyboard.
  5. Continue with the export process. See Adjusting export settings and Create an export.
