Edit or delete location on smart map
Version2025r3
LanguageEnglish
Once you have added locations on your smart map, you can delete them or edit the settings, for example deleting the home location.
Steps:
  1. On the workspace toolbar, select Setup.
  2. To edit a location, right-click the location and select Edit location.
  3. To delete a location, do one of the following:
    • Right-click the location and select Delete location
    • Select the location and press DELETE on your keyboard
