Edit a preset position for a PTZ camera
Version2025r3
LanguageEnglish
You can rename or change the preset positions for your PTZ camera:
  1. Select the view item with the video from the PTZ camera.
  2. On the camera toolbar, select the PTZ icon SC_CameraMenuPTZ_icon.png to open the PTZ menu.
  3. Select Manage PTZ presets and select the PTZ preset position you want to edit:
    • To edit the name, select it and enter a new one.
    • To change the camera position, use the PTZ buttons to go to the desired position and then select Update preset to save.
  4. If you want to sort your presets, use the up or down arrows to reorder the preset positions in the list.
  5. Select Close to exit the window.
