Delete buildings on Smart Map
Version2025r3
LanguageEnglish
If a building is no longer needed, you can delete it. Next time someone logs into XProtect Smart Client or reloads, the building is gone.
Steps:
  1. Open the smart map.
  2. On the workspace toolbar, select Setup.
  3. Do one of the following:
    • Right-click the building and select Delete
    • Select the building, and press DELETE on your keyboard
Tip
An alternate way of deleting a building: In the SC_MapS_ManageDefaultSettings_icon.png Manage default settings, scroll down to the Buildings section, hover on the building, click Delete and then Save.
