Delete bookmarks
Version2025r3
LanguageEnglish
You can delete bookmarks created by yourself or others. If you delete a bookmark, it is removed from the database, and you can no longer find it.
Steps:
  1. On the Search tab, find the bookmarks that you want to delete.
  2. In the search results, hover over each of these bookmarks and select the blue check box SC_SearchResult_CheckBox.png.
  3. In the blue action bar, click SC_Search_Overflow-dots24x24.png and select Delete bookmark. A window appears.
    A message that asks you to confirm that you want to delete bookmarks.
  4. Click Yes to delete the bookmarks.
    Note
    There may be restrictions in your system preventing you from deleting certain bookmarks. In that case, you will be notified.
