Change order of levels in buildings (Smart Map)
Version2025r3
LanguageEnglish
Steps:
  1. Navigate to the building on your smart map. If necessary, zoom in.
  2. Select the building. A pane appears on the right-hand side showing you the levels of the building.
  3. On the workspace toolbar, select Setup.
  4. Click and drag the dotted area SC_MapS_AddRemoveLevels.jpg to the correct position. Any associated devices and custom overlays stay with the level.
  5. Select Setup again to exit setup mode and save your changes.
