Assign a shortcut number to a view
Version2025r3
LanguageEnglish
Assign shortcut numbers to views so you can quickly switch between views. See Default keyboard shortcuts.
  1. Select the view you want to assign a shortcut number to.
  2. At the bottom of the Views pane, in the Shortcut field, enter a shortcut number, and then press Set.
    The shortcut number appears in parentheses before the view name.
