Add location to Smart Map
Version2025r3
LanguageEnglish
To keep track of the places that are of interest to you, you can add locations that allow you to quickly navigate to those places on the smart map.
  1. Select the view that contains the smart map, and click Setup.
  2. If needed, pan and zoom in to the point on the smart map where you want to add the location.
  3. In the toolbar, click SC_MapS_AddLocation_icon.png Add a location, and then click the point on the smart map.
  4. Give the location a name, and then add the following optional details:
    • Specify a zoom level to apply when someone goes to the location on the smart map
    • Select a color for the location icon. Color-coding locations is useful, for example, for distinguishing between types of locations. This could be based on the function of the location or its type, or indicate the location's priority
    • Optional: Make the location your home location. The smart map centers on this location, and applies the default zoom level setting for it, when you click SC_MapS_Home_icon.png Home
