Add a smart map to a view
Version2025r3
LanguageEnglish
If you have created a smart map with a virtual presentation of the protected area and the locations of all cameras and security devices added to the XProtect VMS, you can add this smart map to your views to improve situational awareness
  1. On the System overview pane, drag an existing Smart map item to a view item in your view.
