Generate a service details report
The service details report contains detailed information about the XProtect services running on a specific site. You can use the report to get an overview of your services, the hosts they run on, and their versions.
To generate the report:
Go to your site and click Services.
Click the Reports drop-down and click Service details.
Select the XProtect services and service details to include.
Select the output format. The file is downloaded to your default download location.
