XProtect Remote Manager
Generate a device and device component inventory report
LanguageEnglish
The inventory report helps you identify the devices you have added to a site. The report contains details such as the recording server to which the devices are added, their addresses, and their firmware versions.
You can include device component details, such as the component type, whether it's enabled, and other details.
To generate the report:
  1. Go to your site and click Devices.
  2. Click the Reports drop-down, then click Device inventory.
  3. (Optional) Select to include device components and then select the device components.
  4. Select the device details to include.
  5. Select the output format. The file is downloaded to your default download location.
