Generate a CPU usage report
The report includes a detailed overview of your recording server's CPU usage for a selected period. You can see how many times the recording server's CPU was in Critical, Attention, and Healthy states, and for how long it maintained each state.
To generate the report:
Go to your site and click System insights.
Select the period to include in your report. You can pick a preselected period from the Date and time drop-down, or select a period manually.
Click the CPU usage tab and click Create report.
Select the events you want to include.
Select the output format. The file is downloaded to your default download location.
