Export selected audit log items
Exporting logs helps you to, for example, save log entries beyond the log retention period. You can export logs as comma-separated values (.csv) files.
To export a log file:
From the Audit logs page, select a start and end time range.
(Optional) Use the filter to narrow down your criteria.
Select the items to include in the report. You can export:
Specific items. Click on the check box next to each item you want to include in your report.
All items. Click on the check box in the header row to include all displayed log items.
Click Export selected.
The system generates a file with the log items you selected.
