XProtect Remote Manager
Export selected audit log items
LanguageEnglish
Exporting logs helps you to, for example, save log entries beyond the log retention period. You can export logs as comma-separated values (.csv) files.
To export a log file:
  1. From the Audit logs page, select a start and end time range.
  2. (Optional) Use the filter to narrow down your criteria.
  3. Select the items to include in the report. You can export:
    • Specific items. Click on the check box next to each item you want to include in your report.
    • All items. Click on the check box in the header row to include all displayed log items.
    Click Export selected.
  4. The system generates a file with the log items you selected.
