Enable or disable an alert
The status of an alert profile indicates if it is enabled or disabled. You receive emails only from the alerts you have enabled.
You can only change the status of your own alerts.
On the Home page, click the site that contains the alert profile you want to change the status for.
On the Site health page, click Alert configuration to open the Alert configuration page.
On the Alert configuration page, search for the alert you want to enable or disable. You can apply filters and grouping to narrow the list. Select to enable or disable your alert. To change the status of multiple alerts, select the check box to the left of your alerts and then go to Alert actions to enable or disable them.
