XProtect Remote Manager
Add a device
LanguageEnglish
You can add a new device to a site that is connected to XProtect Remote Manager.
When adding a device, make sure you have installed the device pack for your device. You must also know the IP address, username, and password of the device you want to add.
You can only add one device at a time.
  1. Select the site the device belongs to. To see a list of all sites added by an organization, see Get an overview of your sites.
  2. Select Devices from the panel on the left-hand side. Then, click Add a device.
  3. Enter the device properties:
    Field name
    Description
    Recording server
    Select the recording server to which you want to add the device.
    Driver
    Select the driver for the device you want to add.
    IP address
    Enter the IP address of the new device.
    You can also specify the port number by appending the IP address to a colon, followed by the port number.
    Username
    Enter the username of the device you want to add.
    Password
    Enter the password of the device you want to add.
    Then, click Continue.
  4. In Add device components, specify the following details:
    Field name
    Description
    Device name
    (Optional) Enter a display name for the device.
    Disable device
    By default, the device is enabled. You can select to disable it.
    Device components
    Select which device components (cameras, speakers, microphones, Input, and more) you want to add.
    Select Save and close to save your configuration and add the device.
The system checks for the device state and adds it under the recording server you selected.
