XProtect Remote Manager
About reporting in XProtect Remote Manager
LanguageEnglish
Reporting in XProtect Remote Manager gives you clear insights into system health, performance, and configuration across your XProtect deployments. It helps you understand how your system operates and where attention is needed. It also replaces manual reporting processes and unifies data that was previously spread across different sources.
You can generate the following report types:
  • On-demand reports give you instant insights. You create them manually when you need up-to-date information for a selected period.
  • Scheduled reports run automatically at the times you choose. They help you maintain regular system oversight and support routine reviews.
Reporting supports a wide range of data to help you diagnose issues quickly and provides decision-makers with clear, accessible information for planning and operations. The report types XProtect Remote Manager supports are:
