XProtect OnGuard Integration (XPALeS2)
Milestone XProtect Management Server redundancy solutions with OnGuard
Both of the XProtectManagement Server redundancy solutions are tested and supported to work with the XProtect OnGuard Integration.
  1. Microsoft Clustered Server solution
  2. XProtect Management Server Failover solution
Note
Both XProtectManagement Server redundancy solutions offer data resilience and availability for many XProtect system components. As such integrations which rely on XProtect experience high availability and resilient video access. During failover events, interruption in service still occurs. In particular, the connection to the XProtect Event Server and integration plug-ins or services hosted in the same server environment experience disruption. Tests show the connection to XProtect Access services, and connections to OnGuard re-establish with little or no loss of data, and full system operation restores within minutes.
Tip
Find more information about these redundancy solutions for XProtect here:
XProtect Management Server FailoverFailover management server
Clustering XProtect Management ServersAbout Windows Failover Clustering
