XProtect on AWS BYOL
XProtect on AWS
LanguageEnglish
Designing and deploying hardware infrastructure for your VMS can be time-consuming and costly. With the power of AWS, you can create an infrastructure that supports your XProtect VMS in minutes. You can seamlessly scale your system up or down, add unlimited storage, and provide disaster recovery for you VMS seamlessly.
The XProtect BYOL CloudFormation template deploys all the XProtect VMS core components, including XProtect Smart Client and XProtect Management Client, inside a Virtual Private Cloud (VPC). See The XProtect BYOL CloudFormation template.
On-premise cameras, sensors, and other IoT devices are connected to the VPC through a secure connection. The on-premise devices transmit video, audio, metadata, and other streams to the VMS on AWS without the need for any additional on-premises hardware or gateway equipment for aggregation or buffering.
XProtect on AWS supports different deployment scenarios to fit your needs. You can have single or multisite deployments where the infrastructure is hosted on the cloud or is divided between cloud and on-premises.
