XProtect on AWS BYOL
XProtect on AWS licensing
LanguageEnglish
The licensing of XProtect BYOL follows the same license terms and uses the same Software License Code (SLC) as traditional on-premises deployments.
Important
If you have not yet purchased a license for your XProtect product, you can get a license from a Milestone distributor or reseller using the Milestone partner network.
You might need to upgrade the license to match the XProtect release versions that are available on AWS Marketplace.
To see information about the product's features, see: Milestone XProtect® Product Comparison Tool.
