XProtect on AWS BYOL
Subscribe to XProtect in AWS Marketplace
LanguageEnglish
To deploy the XProtect CloudFormation stack, you must first subscribe to the product in AWS Marketplace.
  1. Go to https://aws.amazon.com/marketplace.
  2. Enter Milestone in the search bar. Select to subscribe to MilestoneXProtect (BYOL)
Then, select Continue to Subscribe.
Tip
The charges for using the AWS services are listed when you subscribe to your XProtect product in AWS Marketplace.
After you have subscribed, you are ready to deploy XProtect on AWS.
