XProtect on AWS BYOL
Stack details
Last Updated: 4 minute read
In the second step of the deployment process, you configure the VMS and network settings.
Stack name
Parameter
Description
Stack name
Specify a name to identify the XProtect BYOL CloudFormation stack with.
XProtect Configuration
Parameter
Description
XProtect language
Select the display language of the installed XProtect products.
Retention time
Select the number of days video recordings are saved for in the media database.
The default retention time is seven days.
If you increase the Retention time from the default value, you should also increase the size of the Media database volume accordingly.
EC2 Configuration
Parameter
Description
User name for the administrator account
Specify a user name for the administrator account. You use this account to access your EC2 instance using Remote Desktop Protocol (RDP).
Password for the administrator account
Specify a password for the administrator account.
The password must be between 8 and 32 characters long and contain at least:
  • One number
  • One special character
  • Capital letter
Instance type
Select the type of the EC2 instance.
The default instance type is c5.large.
Important
If the template fails to deploy due to the selected Instance type, restart the deployment and select a different availability zone.
To learn more about the different instance types, go to Instance types.
Operating System Volume Size
Select the size in GB of the Elastic Block Storage (EBS) volume that contains all VMS components except the media database.
The default volume size is 150 GB.
Delete Operating System Volume
Select if the operating system volume (disk 0) should be deleted when you terminate the EC2 instance.
Important
Terminating the EC2 instance or deleting the EBS operating system volume does not unsubscribe you from XProtect BYOL.
Media Volume Size
Select the size in GB of the EBS volume that contains the media database used to store video recordings.
The default volume size is 100 GB.
Tip
Milestone recommends that you configure the media volume size to hold a minimum of 24 hours of video recordings. You can use another storage option to archive your recordings if you need to keep them for a longer time period.
Delete Media Volume
Select if the media database volume (disc 1) should be deleted when you terminate the EC2 instance.
Instance Hostname (optional)
Create a custom name for the EC2 instance to find it in your network environment.
If you leave this field blank, a random instance name is assigned to the EC2 instance.
Important
You cannot change the Instance Hostname after deployment.
Network configuration
Parameter
Description
Availability zone
Select an AWS availability zone within your selected region that the EC2 instance deploys in.
Important
If the script fails to deploy due to the selected Instance type, restart deployment and select a different Availability Zone.
RDP ingress CIDR block
Specify the range of inbound IP addresses that will access the VPC using RDP.
VPC CIDR block
Specify the range of IP addresses that creates the virtual network of the VPC.
The default Classless Inter-Domain Routing (CIDR) IP block is 10.0.0.0/16.
Subnet CIDR block
Specify the range of IP addresses that creates the subnet of the VPC.
The default CIDR IP block is 10.0.0.0/24.
Plug-ins
Parameter
Description
Surveillance Bridge by Tiger Surveillance
Select if you want to install Surveillance Bridge for archiving recordings. This plug-in requires addiional licensing. See Surveillance Bridge.
Fully-managed SQL Server database
Parameter
Description
Amazon RDS for SQL Server
Select if you want to use Amazon RDS instead of SQL Server. If you select true, the wizard deploys an RDS DB instance of SQL Server Express 2022 in the selected region. If you select false, the wizard installs SQL Server on the EBS volume that is attached to the EC2 instance.
Instance Class
Select an instance class that matches your needs. You can select an instance class from the db.t3 instance class type.
Allocated Storage
Select the allocated storage capacity for the DB instance.
Database subnet CIDR Block
Select a collection of private subnets that you want to designate for your DB instance.
