XProtect Mobile server
Show/edit port numbers
Version2026 R2
LanguageEnglish
  1. Right-click the Mobile Server Manager icon and select Show/edit port numbers.
  2. To edit the port numbers, enter the relevant port number. You can indicate a standard port number for HTTP connections or a secured port number for HTTPS connections, or both.
  3. Click OK.
