XProtect Mobile server
Change investigations folder
Version2026 R2
LanguageEnglish
The default location of investigations is in the ProgramData folder. If you change the default location of the investigations folder, the existing investigations are not automatically copied to the new location, nor are they deleted. To change the location where you save the investigation exports on your hard disk:
  1. Right-click the Mobile Server Manager icon and select Change investigations folder.
    The Investigations location window opens.
  2. Next to the Folder field that shows the current location, click the folder icon to browse for an existing folder or create a new folder > Click OK.
  3. From the Old investigations list, select the action that you want to apply to the existing investigations that are stored in the current location. The options are:
    • Move: Moves the existing investigations to the new folder
      Note
      If you do not move the existing investigations to the new folder, you will no longer be able to see them.
    • Delete: Deletes the existing investigations
    • Do nothing: The existing investigations remain in the current folder location. You will no longer be able to see them after you have changed the default location of the investigations folder
  4. Click Apply > Click OK.
