Show/edit port numbers
Right-click the Mobile Server Manager icon and select Show/edit port numbers.
To edit the port numbers, enter the relevant port number. You can indicate a standard port number for HTTP connections or a secured port number for HTTPS connections, or both.
Click OK.
