Naming an output for use in XProtect Mobile client and XProtect Web Client
To get actions to show correctly together with the current camera, you must create an output group that has the same name as the camera.
Example:
When you create an output group with outputs attached to a camera named "AXIS P3301 - 10.100.50.110 - Camera 1", you must enter the same name in the Name field (under the Device group information).
In the Description field, you can add a further description, for example, "AXIS P3301 - 10.100.50.110 - Camera 1 - Light switch".
Important
If you do not follow these naming conventions, actions are not available in the action list for the associated camera's view. Instead, actions appear in the list of other actions on the Actions tab.
