XProtect Mobile server
Install the XProtect Mobile server
Last Updated: 4 minute read
Once you have installed the XProtect Mobile server, you can use the XProtect Mobile client and XProtect Web Client with your system. To reduce the overall use of system resources on the computer running the management server, install the XProtect Mobile server on a separate computer.
The management server has a built-in public installation webpage. From this webpage, administrators and end-users can download and install the required XProtect system components from the management server or any other computer in the system.
Note
XProtect Mobile server is automatically installed when you install the "single computer" option.
Download the XProtect Mobile server installer
  1. Enter the following URL in your browser: http://[management server address]/installation/admin where the [management server address] is the IP address or the host name of the management server.
  2. Select All Languages for the XProtect Mobile server installer.
  1. Run the downloaded file. Then, select Yes to all warnings.
  2. Select a language for the installer. Then, select Continue.
  3. Read and accept the license agreement. Then, select Continue.
  4. Select the installation type:
    • Select Typical to install XProtect Mobile server and plug-in
    • Select Custom to install only the server or only the plug-in. For example, installing only the plug-in is useful if you want to use Management Client to manage XProtect Mobile servers but don't need an XProtect Mobile server on that computer
      Note
      XProtect Mobile plug-in is required on the computer running Management Client to manage XProtect Mobile servers in Management Client.
  5. For custom installation only: Select the components that you want to be installed. Then, select Continue.
  6. Select the service account for the mobile server. Then, select Continue.
    Note
    To change or edit the service account credentials at a later stage, you have to reinstall the mobile server.
  7. For custom installation only: Log in with an existing VMS user account when connecting to the surveillance system:
    • Service account is the account you selected in step 8. To connect using this account, make sure that the service account is a member of a domain to which the management server has access
    • Basic user. Use a basic user when the service account is not a member of a domain to which the management server has access
    Note
    To change or edit the service account or the basic user credentials at a later stage, you have to reinstall the mobile server.
    Click Continue.
  8. In the Server URL field, fill in the primary management server address.
    For custom installation only: Specify the connection ports for communication with the mobile server. Then, select Continue. In a typical installation, the connection ports get the default port numbers (8081 for the HTTP port and 8082 for the HTTPS port).
  9. On the Assign a mobile server data protection password page, enter a password to encrypt your investigations. As a system administrator, you will need to enter this password to access the mobile server data during system recovery or when expanding your system with additional mobile servers.
    Warning
    You must save this password and keep it safe. Failure to do so may compromise your ability to recover mobile server data.
    If you do not want your investigations to be password-protected, select I choose not to use a mobile server data protection password, and I understand that investigations will not be encrypted.
  10. Specify the mobile server encryption. Then, select Continue.
    On the Select encryption page, you can secure the communication flows:
    • Between the mobile servers and the recording servers, data collectors, and the management server. To enable encryption for internal communication flows, in the Server certificate section, select a certificate.
    • Between the mobile servers and clients. To enable encryption between the mobile server and clients that retrieve data streams from the mobile server, in the Streaming media certificate section, select a certificate.
    Note
    If you do not enable encryption, some features in some clients will not be available.
    For more information about establishing secure communication in your system, see Mobile server data encryption.
    You can also enable encryption after installation completes from the Mobile Server Manager tray icon in your operating system's taskbar. See Enable encryption on the mobile server.
  11. Select the file location and product language and then select Install.
    When the installation is completed, a list of successfully installed components appears.
