XProtect Mobile server
Before you install the XProtect Mobile server
Version2026r1
LanguageEnglish
For information about the system requirements for the various VMS applications and system components, go to the Milestone website (https://www.milestonesys.com/systemrequirements/).
Milestone recommends that you install the XProtect Mobile server on a separate computer. Before you install and start using the XProtect Mobile server component, make sure of the following:
  • You have set up cameras and views in XProtect Management Client.
  • The mobile server computer resolves the host names of the computers that run the other VMS server components.
  • The management server computer resolves the host name of the mobile server computer.
  • You have a running VMS installed.
  • You have configured at least one VMS user. To connect to the surveillance system, the role to which this user is added requires permissions for the management server:
    • Connect
    • Read
    • Edit
  • If you are upgrading your system, make sure that the version of the XProtect Mobile plug-in matches the version of the mobile server. Your system might not function properly if the versions of the plug-in and mobile servers are not identical.
