Show status
Right-click the Mobile Server Manager icon and select Show Status or double-click the Mobile Server Manager icon to open a window that shows the status of the XProtect Mobile server. You can see the following information:
Name | Description |
Server running since | Time and date of the time when the XProtect Mobile server was last started. |
Connected users | Number of users currently connected to the XProtect Mobile server. |
Hardware decoding | Indicates if hardware-accelerated decoding is in action on the XProtect Mobile server. |
CPU usage | How many % of the CPU is currently being used by the XProtect Mobile server. |
CPU usage history | A graph detailing the history of CPU usage by the XProtect Mobile server. |
