XProtect Mobile server
Change data protection password
Version2025r3
LanguageEnglish
The mobile server data protection password is used to encrypt investigations. As a system administrator, you will need to enter this password to access the mobile server data in case of system recovery or when expanding your system with additional mobile servers.
To change the mobile server data protection password:
  1. Right-click the Mobile Server Manager icon and select Change data protection password settings. A dialog box appears.
  2. In the New password field, enter your new password.
  3. Re-enter the new password in the Confirm new password field.
  4. (Optional) If you do not want your investigations to be password protected, select I choose not to use a mobile server data protection password, and I understand that investigations will not be encrypted.
  5. Click OK.
Important
You must save this password and keep it safe. Failure to do so may compromise your ability to recover mobile server data.
