XProtect Mobile client
Using actions in XProtect Mobile
Version2026 R2
LanguageEnglish
If your system administrator has given you permission, you can trigger actions if you need to. In the clients, actions are outputs and events that you can activate. For example, you can:
  • Start or stop recording.
  • Switch to a different frame rate.
  • Trigger SMS and email notifications.
  • Move PTZ cameras to PTZ preset positions.
  • Activate hardware output.
