Picture-in-picture
Using picture-in-picture in playback mode
If you see something that you want to investigate, but you don't want to stop observing the current situation, you can display live video using picture-in-picture (PiP) and play back video at the same time.
Switch from live mode to playback mode by tapping
(Android) or
(iOS).Depending on the operating system on your device:
Android - Tap
.iOS - Tap
Note
Incoming audio is not available in PiP when you use the feature while you view video recordings.
Note
To move the PiP window, tap and hold, and drag the PiP window to the preferred place on the screen.
Return to live video
To view the live video in full screen:
Double-tap the PiP window.
Tap
(Android) or
(iOS).
Using background picture-in-picture
For Android users
To continue viewing live video, while you browse other content on your mobile device:
Minimize the app. The picture-in-picture (PiP) window displays at the bottom-right corner of the screen. Double-tap the PiP window to enlarge it.
Note
To use the PiP action buttons, tap the PiP window. Options:
To enable or disable the background picture-in-picture, tap
.To add a bookmark, tap
.To return to full screen, tap
.To close the PiP window, tap
