XProtect Mobile client
Requirements for using push-to-talk
To use the push-to-talk (PTT) feature on your mobile device in your XProtect VMS, you must have:
  • Cameras with speakers attached.
  • Sufficient user permissions.
    Note
    Access to the push-to-talk feature may be restricted depending on your user permissions. Ask your system administrator if in doubt.
  • Allowed the XProtect Mobile app to use the microphone of your mobile device.
  • HTTP or HTTPS with a CA certificate connection.
    If you want to use an HTTPS connection, a digital certificate from a certificate authority (CA) must be installed on your XProtect Mobile server.
