XProtect Mobile client
React to a notification
Version2025r3
LanguageEnglish
XProtect Mobile can notify you when something requires your attention even when you're not using the app. For example, the system can notify you when an alarm is triggered.
React now or later
To react immediately, tap the notification to open XProtect Mobile and investigate what happened. When you do this, XProtect Mobile does not store the notification.
If you don't want to react immediately, you can view the notification later:
  • Android - Go to the Notification Area. Open the notification drawer to see the details.
  • iOS - Go to the lock screen or the Notification Center.
