XProtect Management Server Failover
Step I: Start the configuration on Node 2
Version2026 R2
LanguageEnglish
After you have checked the prerequisites and prepared your system, you can start with the configuration of the failover cluster with data replication.
On Node 2:
You are now ready to continue on Node 1. See Step II: Continue the configuration on Node 1.
