Prerequisites for running a recording server or failover recording server on the cluster nodes
Installing the recording server or failover recording server on the cluster nodes requires additional steps.
You can install a recording server or failover recording server on one or both nodes. For example, you can install:
A recording server on Node 1.
A recording server on Node 1 and a failover recording server on Node 2.
A recording server on Node 1 and Node 2.
Before you configure the management server failover, consider the following factors:
Environment - The nodes can run in a domain or workgroup environment.
Failover recording server setup - If you configure a failover recording server on any of the nodes, you can use it in a hot standby or a cold standby setup. For an example of a cold standby setup, see Failover group in cold standby.
Encryption (optional)- To encrypt the connection between the VMS components, you must install the SSL certificate for the recording server on the recording server computer. Then, you must enable encryption for the recording server from the recording server's Server Configurator.
Services - The XProtect Recording Server service and the configuration wizard for XProtect Management Server Failover need port 9001 to operate. To avoid conflicts, you must either use another port for the Milestone XProtect Recording Server service or stop the service when you configure or remove the configuration from the failover cluster.
We strongly recommend that you change the port of the recording server's web API before you start. This prevents unexpected port conflicts, especially on systems that use encryption.
Storage - Store the media database of the recording servers and failover recording servers on a different disk volume from the SQL Server database.
This example shows a failover group in cold standby where the failover recording server and the management server share the cluster nodes:
Server | Role |
Server 1 | Recording server and management server failover node (normally the passive node) |
Server 2 | Recording server |
Server 3 | Recording server. You can add more recording servers to the failover group. |
Server 4 | Failover recording server and management server failover node (normally the active node) |
Server 1 and Server 4 are the two cluster nodes.
The following table shows what happens when a server fails:
Failed server | Result |
Server 2, Server 3, or another recording server in the failover group | The failover recording server on Server 4 takes over recording for the failed server. |
Server 4 | The management server fails over to Server 1. Recording is not affected. |
Server 1 | The failover recording server on Server 4 takes over recording for Server 1. The management server continues to run on Server 4. |
Note
In this setup, both the recording servers and the management server are protected against one failure at a time. Restore the failed server before you rely on failover again.
