XProtect Management Server Failover
Identify the hostname of a node
Version2026 R2
LanguageEnglish
The failover web console represents the primary computer as node1 and the secondary computer as node2. To see the host name that corresponds to a node:
  1. From the failover web console, click the node you want to see the hostname information about.
  2. Go to the Information tab.
  3. In the Hostname field, you can see your hostname.
