XProtect Management Server Failover
Client applications
Version2026 R2
LanguageEnglish
Replace the management server hostname with the cluster address when logging in from:
  • XProtect Management Client
  • XProtect Smart Client
  • XProtect Mobile Client
  • XProtect Web Client
Tip
After completing the configuration, verify that failover is working correctly by checking that services move to the active node and clients can reconnect using the cluster address.
