XProtect Management Server Failover
XProtect Management Server Failover licenses
Version2025r3
LanguageEnglish
XProtect Management Server Failover comes with a three-day demo license.
To use the failover cluster for unlimited period, you must purchase a license and provide your Milestone representative with the Node 1 and Node 2 hostnames. The license is issued specifically for these hostnames and can only be used with them.
Important
If you do not add your XProtect Management Server Failover license, the Management Server service will stop after three days.
You can add the license during the failover cluster configuration or afterward. See Add a license for XProtect Management Server Failover.
