XProtect Management Server Failover
Ports used by XProtect Management Server Failover services and modules
Service
Default ports
Purpose
safeadmin
Remote access on UDP port 4800 and local access on UDP port 6259
Communicate with other safeadmin instances on other computers. The main and mandatory administration service that is started at boot.
safewebserver
Local and remote TCP access on port 9010 for the HTTP web console or port 9453 for the HTTPS web console
The safewebserver service is a standard Apache web service that is mandatory for running the web console, the distributed comman-line interface, and the <module> checkers.
safecaserv (optional)
Local and remote access on TCP port 9001
The safecaserv service is a web service for securing the web console with the SafeKit PKI.
safeagent (optional)
Local and remote access on UDP port 3600
The safeagent service for SNMP v2.
Failover cluster modules
The ports values of one module are automatically computed depending on its module ID.
Module
Ports
Purpose
heart
port=8888 +(id-1)
UDP port used for sending heartbeats between the servers.
rfs
safenfs_port=5600 +(id-1)x4
TCP port used for replications requests between the servers.
