XProtect Management Server Failover
Install the server certificate on a computer
Version2025r3
LanguageEnglish
Install the server certificate on all computers that will access the failover web console.
  1. Copy the serverCert.crt file from Node 1 to the computer that needs to access the failover web console.
  2. Right-click the server certificate and select Install Certificate.
  3. In the Certificate Import wizard, choose the Store Location:
    • For Node 1 and Node 2, select Local Machine
    • For all other computers, select Current User
    Select Next to continue.
  4. Select Place all certificates in the following store and specify a folder.
  5. Select Browse, and then Trusted Root Certification Authorities.
  6. Select OK and Next.
  7. On the Completing the Certificate Import Wizard dialog, select Finish.
    If you receive a security warning that you are about to install a root certificate, select Yes to continue.
    If the import has succeeded, a confirmation dialogue box appears.
  8. Verify that the server certificate is listed in the center view of the Trusted Root Certification Authorities subtree.
