Configuring the failover cluster without database replication
You exclude the SQL Server databases from data replication by connecting to a SQL Server instance hosted on your network.
To configure the failover cluster, you switch between Node 1 and Node 2 in the following order:
Step I: Start the configuration on Node 2.
Step II: Continue the configuration on Node 1. Once done, move to Node 2.
Step III: Finish the configuration on Node 2
Important
During the configuration, the XProtect VMS users won't be able to log in to any XProtect client during configuration.
