XProtect Management Server Failover
Configuring the failover cluster with database replication
Version2025r3
LanguageEnglish
If you have installed the management server component with SQL Server on both nodes, you can use data replication of the SQL Server databases.
To configure the failover cluster, you switch between Node 1 and Node 2 in the following order:
Step I: Start the configuration on Node 2. Once you prepare Node 2, move to Node 1.
Step II: Continue the configuration on Node 1. Once done, move to Node 2.
Step III: Finish the configuration on Node 2
Important
During the configuration, the XProtect VMS users won't be able to log in to any XProtect client during configuration.
