XProtect Management Server Failover
Add a license for XProtect Management Server Failover
Version2025r3
LanguageEnglish
You receive the XProtect Management Server Failover license in your email.
You have the option for when to add the license:
Add a license from the Manage your configuration page
You must add the same license on both nodes.
  1. On Node 1, in the notification area, right-click the Management Server Manager tray icon and select Configure failover management server.
  2. Select Apply failover license and select Continue.
  3. On the Add a failover license on this computer page, select Browse and select your XProtect Management Server Failover license. Select OK, then Continue. A message informs you that the configuration of the failover management server is successful.
  4. Repeat steps 1 to 4 on Node 2.
