XProtect Mobile client
Version2026 R2
LanguageEnglish
XProtect Mobile client is a mobile surveillance solution closely integrated with the rest of your XProtect system. It runs on your Android tablet or smartphone or your Apple® tablet, smartphone, or portable music player and gives you access to cameras, views, and other functionality set up in the management clients.
Use the XProtect Mobile client to view and play back live and recorded video from one or multiple cameras, control pan-tilt-zoom (PTZ) cameras, trigger output and events, and use the Video push functionality to send video from your device to your XProtect system.
Mobile client running on an Android phone, an iPhone, and a tablet.
If you want to use the XProtect Mobile client with your system, you must have a XProtect Mobile server to establish the connection between the XProtect Mobile client and your system. Once the XProtect Mobile server is set up, download the XProtect Mobile client for free from Google Play or App Store to start using XProtect Mobile.
You need one device license per device that should be able to push video to your XProtect system.
