XProtect Management Server Failover
Version2026 R2
LanguageEnglish
If a standalone computer running the management server or SQL Server has a hardware failure, it does not affect recordings or the recording server. However, these hardware failures can result in downtime for operators and administrators who have not logged in to the clients.
