XProtect Access for administrators
Version2026 R2
LanguageEnglish
XProtect Access is an extension of XProtect. If a dedicated XProtect plug-in exists for that access control system, it enables organizations to integrate their access control systems with XProtect.
To use this extension, you must purchase:
  • 1 base license for each XProtect system you want to use with XProtect Access.
  • 1 door license for each door you want to control through XProtect.
XProtect Access includes:
  • A shared user interface for access control systems in XProtect Smart Client.
  • Powerful integration of access control systems.
  • Live monitoring of events at access points.
  • Operator-assisted access requests.
  • Integrations with maps.
  • Alarm definitions for access control events.
  • Investigation of events at access points.
  • Centralized overview and control of door states.
  • Cardholder information and management.
Whenever a user in XProtect Smart Client takes any access-related action, such as opening a door or denying entry, the system records it in the Audit log.
