View encryption status on a failover recording server
Version2026 R2
LanguageEnglish
To verify if your failover recording server uses encryption, do the following:
  1. In the Site Navigation pane, select Servers > Failover Servers. This opens a list of failover recording servers.
  2. In the Overview pane, select the relevant recording server and go to the Info tab.
    If encryption is enabled to clients and servers that retrieve data streams from the recording server, a padlock icon appears in front of the local web server address and the optional web server address.
    Example of enabled encryption for Local web server address and web server address in the Properties pane.
