Update site information of child sites
Version2026 R2
LanguageEnglish
Note
This section is only relevant if you use XProtect Corporate or XProtect Expert 2014 or newer.
You can read the information about the site, when you pause your mouse over the site name in the Federated Site Hierarchy pane. To update information about the site:
  1. Log into the site.
  2. Click Site Navigation pane and select Site Information.
  3. Click Edit and add the relevant information in each category.
