Speech tab (roles)
Version2026 R2
LanguageEnglish
Relevant only if you use speakers on your system. Specify the following permissions for speakers:
Name
Description
Speak
Determine if users should be allowed to talk through the selected speaker(s). Specify the time profile or leave the default value.
Speak priority
When several client users want to talk through the same speaker at the same time, conflicts may occur.
Solve the problem by specifying a priority for use of the selected speaker(s) by users/groups with the selected role. Specify a priority from Very low to Very high. The role with the highest priority is allowed use the speaker before other roles.
Should two users with the same role want to speak at the same time, the first come, first served-principle applies.
